gluciano
- May 13, 2009
- Fort Lauderdale FL
- 95 Splorer XLT 2 WD 4L
95 X 4L with the auto tranny with O/D
The other day after getting off of the highway from driving 5 miles the trans started to act up. The OD light was blinking and it wouldn't want to shift out of second gear, when it would shift to third it's slip in. Shifting from 1st to 2nd was a very firm shift and from 2nd to 3rd it would hold 2nd for a while and then glide into 3rd.
I took my code reader and did an engine running scan to see if I can get codes, nothing came up and the system passed. I then drove the X around for a few miles and the trans was acting fine, shifting fine, no OD light. Again I took it on the highway for a few miles, came off of it and it began to have the problems again. What's odd is that after I put my code reader on it and test it the problem goes away.
Has anyone had a similar problem to this? Is the trans controlled by the ECM or does it have a separate computer? I really think this is a sensor issue of some kind rather than electric since the problem goes away after I try and pull codes.
