rickb928
- June 17, 2003
- Gilbert, AZ
- '00 V8 XLT
I'm really due to replace the front calipers, will do the rears as well, but a question.
My Ex has 310k on it, and the brake fluid in the reservoir is not clean - dark, had filmy stuff in it, last pad change I siphoned it nearly dry and filled new, but the new is of course discolored. Bleeder screws are rusted in place. My shop wants to replace calipers etc and bleed/FLUSH the brakes, but bleeding what's in there scares me. What will happen if this fluid gets flushed through the ABS system? I don't feel like doing a brake job and buying a $1200 ABS block cause my shop guy says it won't be a problem. I learned my lesson flushing my tranny at 236K+/-, that was the end of that.
So, flushing this probably ancient (150K+) fluid through the ABS, no problem or not a good idea, and if not a good idea, how do ya ever flush the brakes? Is there a bypass, or do I pull off the ABS lines and then reconnect them?
ps- ABS works FINE, no problems, no codes, stellar system. I don't need to clog it up and go through that.
Thanks!
Thanks!
