95 Camshaft Position Sensor Install ?? | Ford Explorer Forums - Serious Explorations
cbridge
baltimore, maryland
93 xlt
I'm redoing my Heads and damaged the Camshaft Position Sensor. I removed the Camshaft Position Sensor and didn't make a note of how it was installed. I have the engine at TDC and need help in installing the new sensor correctly. I noticed there is a Clear plastic/glass on top of the Camshaft Position Sensor and the 1/2 moon of the CAM can be seen. The back end of the 1/2 moon (about 33%) of it is red. I can see the Center line in the glass but I'm not sure if there is more than one way to install the Camshaft Position Sensor. I would like to start re-installing the heads and intake manifold this weekedd, but want to put back in the sensor 1st. Any help appreciated. :exp::thumbsup:
