Well...
Does it bind/hop every time you turn, or just some of the time?
If it only happens occasionally:
This is normal, because 4wd auto will temperarly lock the transfer case if it notices slippage. So it really depends on the road conditions.
"When you engage 4auto on a '95-'96, the GEM switches the signal to a vacuum solenoid (insert picture here) which locks the CAD, thereby connecting the front half of the drivetrain and forcing the front driveshaft to turn with the wheels. Then, when the GEM determines that the
rear wheels are turning faster than the fronts, it momentarily locks the transfer case, linking the front and rear driveshafts together for a period of time. The GEM then unlocks the transfer case, checks for slipping again, and, if necessary, locks the transfer case again.
This produces some clunking and unconventional engagement and disengagement that many people don't like." Read the rest here:
http://www.explorer4x4.com/controltrac_mod.htm
If it happens 100% of the time:
There could possibly be a problem, on later 2nd gens the
rear axle speed sensor can begin to fail (kinda common). The sensor is located on the rear differential. But I'm not sure if 1995 2nd gens has the same setup.:scratch:
Post
#4 might help:
http://www.explorerforum.com/forums/showthread.php?t=201445
Hope this helps:biggthump
