95 Explorer shakes when first started | Ford Explorer Forums - Serious Explorations
james.oco
Central NJ
1995 Ford Explorer
I have a 95 Explorer, and occasionally it will shake when I first start it up. The shaking stops once the accelerator is pressed and it is no longer idling. This only occurs when first started, and does not occur within the remainder of the trip. Any ideas on what could be causing this? Thanks in advance.
Is it time for a tune up?
check or replace your spark plugs and plug wires. Sounds like your not firing on all cylinders when cold. An air leak in the manifold gasket will also make it run rough when cold.
