95 explorer surging
OregonXJ
Oregon
95 XLT
Hey everyone,
I have a 95 explorer that surges very lightly at low speeds. During idle it fluctuates between like 7-800 and 1000. During the idle I can hear the compressor clutch kicking on and then back off. The that time is when the rpms are fluctuating.
Additionally I have the check engine light come on only when I'm driving and then sometimes turns off while driving. It is always off when I start driving, and sometimes does not come on at all on short drives.
I went to Autozone and the guy there hook up a code reader to the plug under the dash but it didn't say anything. Does this year even work with the obdII reader?
Anyways, any help would be appreciated.
JHolben
Hampstead, NC
95 Explorer Sport
I see this thread was never responded to. FYI -My 95 Explorer w\4.0 EFI has the ports for OBDII under the bottom of the dash above the gas pedal and an OBDI port beside the brake master cylinder under the hood. The OBDII port above the pedal is NOT functional. I must use the OBDI port under the hood. BTW..I have the same problem with my 95 Explorer.
B 1996 explorer surging at idle Stock 1995 - 2001 Explorers 1
B 1996 explorer surging at idle Stock 1995 - 2001 Explorers 21
V Surging/Missfire Issue 99 V8 Explorer Stock 1995 - 2001 Explorers 8
M And here I was, thinking my Explorer was a big vehicle... Stock 1995 - 2001 Explorers 8
K Enduro explorer Stock 1995 - 2001 Explorers 7
L O/D off light flashing in 99 Ford Explorer. Stock 1995 - 2001 Explorers 6
M ECT replacement 1996 Explorer 4.0 OHV Stock 1995 - 2001 Explorers 2
N 1996 Explorer Sport 4.0L OHV Camshaft syncronizer positioning Stock 1995 - 2001 Explorers 8
K 96 Explorer fuel pump not activating Stock 1995 - 2001 Explorers 2
S Is a 1998 Explorer Limited 5.0 Full Time 4WD w/transfer case towable behind an RV with all four wheels down? Stock 1995 - 2001 Explorers 1
G My Explorer does not sit right Stock 1995 - 2001 Explorers 4
C ABS Warning Light on Explorer Stock 1995 - 2001 Explorers 0
F Switch from 5w30 to 5w20 in the Explorer - Tech Service Bulletin Stock 1995 - 2001 Explorers 35
S 1. Both Differential Oil changes plus Transfer Case, Transmission Oil Service 1998 EXPLORER LIMITED 5.0, 4 door, air suspension, AWD, Stock 1995 - 2001 Explorers 20
D 2000 Explorer 5.0 AWD Electrical Question Stock 1995 - 2001 Explorers 2
4pointslow My 2000 Explorer 4 door XLT Stock 1995 - 2001 Explorers 68
M Compatibility of 2nd Generation Explorer Limited Options with XLT Stock 1995 - 2001 Explorers 3
T 1996 explorer 4.0 ohv Stock 1995 - 2001 Explorers 4
E Can this '95 Explorer make it across the country? Stock 1995 - 2001 Explorers 25
C 99 explorer won't start Stock 1995 - 2001 Explorers 7
A 1997 Ford Explorer 4x4 Rear Differential Stock 1995 - 2001 Explorers 2
allmyEXes 1997 Explorer Key less Entry Stock 1995 - 2001 Explorers 8
I Can't program key fobs 1999 Explorer Stock 1995 - 2001 Explorers 2
W Problem with ABS on 1998 Ford explorer XLT Stock 1995 - 2001 Explorers 2
J Coolant Temperature Sensor Wiring 1999 Explorer Stock 1995 - 2001 Explorers 2
D Lost 99 Explorer keys/PATS but have a rolled 2002 Explorer w/keys and PATS Stock 1995 - 2001 Explorers 2
J Inspect Explorer for me in Arkansas Stock 1995 - 2001 Explorers 3
4 1996 Explorer XLT Stock 1995 - 2001 Explorers 13
D 99 Explorer Limited Fuel Pressure Sensor location Stock 1995 - 2001 Explorers 8
D Please help with posting a picture of your 1995 Explorer XLT Power Distribution Box Stock 1995 - 2001 Explorers 8
A no A/C 2000 5.0 Limited Explorer Stock 1995 - 2001 Explorers 15
P 1996 Explorer - what type atf Stock 1995 - 2001 Explorers 3
L 1996 Ford Explorer XLT ABS Module Failure Stock 1995 - 2001 Explorers 9
L Are all Explorer ABS modules the same 1993 to 1999 Stock 1995 - 2001 Explorers 1
M New addition, 2000 Explorer Limited Stock 1995 - 2001 Explorers 4
B No gasket between Oil pump and block? 99 Explorer 4.0 OHV. Stock 1995 - 2001 Explorers 4
D 1996 Explorer XLT: Rear Frame "issues" Stock 1995 - 2001 Explorers 26
allmyEXes 1997 Explorer rear hatch handle broken (internally) Stock 1995 - 2001 Explorers 10
D Hello, I'm in process of purchasing a 1999 Explorer XLT from our neighbor. Has a No Start crank over. Stock 1995 - 2001 Explorers 5
S 99 Ford Explorer 4.0 SOHC Help Stock 1995 - 2001 Explorers 19
D 1999 explorer 4.0l SOHC having issues Stock 1995 - 2001 Explorers 2
T 1996 Ford Explorer front diff Stock 1995 - 2001 Explorers 4
D stock 01 explorer, issue with the tach needle bouncing ???? Stock 1995 - 2001 Explorers 3
S Searching for 1996 Explorer 2WD Spindles Stock 1995 - 2001 Explorers 3
D 98 ford explorer engine missing Stock 1995 - 2001 Explorers 10
allmyEXes 1997 Explorer 4.0 SOHC Automatic 2WD Test drive Stock 1995 - 2001 Explorers 13
I 96 explorer a/c electrical question Stock 1995 - 2001 Explorers 25
V 2001 Explorer Sport Rear Hatch Question Stock 1995 - 2001 Explorers 1
L 98 explorer cruise control switch issue Stock 1995 - 2001 Explorers 2
B Explorer meet and run? Stock 1995 - 2001 Explorers 1
Similar threads
