95junktruck
- March 10, 2007
I am about to replace the lower driver side ball joint and I have a few questions if anyone can chime in that would be great.
First, Do you have to remove the upper ball joint and tie rod to get to the lower ball joint?
Also do you have to replace them in pairs, If I do the lower left do I now have to do the lower right?
How can I test to make sure the ball joint really is bad before I yank it out?
And does anyone have any tips or tricks that would help that are not in the two ball joint replacement threads?
Thanks
Thanks
