95 only shifts when i let off gas | Ford Explorer Forums
leftysdad
Greenville sc
93 Eddie B
95 4.0 will only shift from 1 to 2nd if I let off the throttle, no flashing OD light....just won't shift until I let off.....other gears are fine.....ALSO! Someone before me did something to where I don't have check engine light....don't even light up when I turn key on
Thanks
Missing CEL is an easy fix. Easier with Haynes or similar repair manual (can get from Auto Zone or similar, or order online), but just locate and remove the three screws/bolts underneath the radio panel, and pull the panel out just a bit.
Locate and remove the screws/bolts on the underside of the shade above the gauge cluster. Check and see if there are screws/bolts on the kneecap buster holding the dash cover on before attempting to remove; it's super easy to crack the dash panel while removing, even if you put the steering wheel as far down as possible.
Removing the gauge cluster after that is easy, just unscrew the bolts and pull forward, but be careful not to damage the wiring harness behind it. Got to reach behind it and disconnect before removal.
After that, it's a simple matter of identifying which sizes of light bulbs you need. There are two different sizes, one size for the back lights and an other size for the warning lights. Just replace all of 'em, they're cheap enough at parts stores, and keep the old ones for spares.
As far as the shifting goes, I'd first make sure that the transmission fluid is fresh and full, not overfilled. Beyond that, I can't help too much, but search around and see if others have similar issues. It might be time for a rebuild.
Get one of those $10 hand siphons from Walmart / Harbor freight ...siphon out a quart through dip stick....replace removed quart with Lucas trans repair in a bottle...if that don't work rebuild time likely.... the Lucas stuff does work some miracles though....more then snake oil....
How to access instrument bulbs:
(*Upon reinstallation of cluster... tilt top back first then slide into place)
Check your TPS for smooth operation and proper voltage. The trans will hold up-shifts if it thinks you’re at or near WOT
