Su Dog
- January 10, 2010
- SC
- 1996 Explorer
I am working on a future budget build in the next few months. I want to switch out the old BII coil and leaf springs and I am going to try using the 1996 explorer. Both Suv's are 4wd. Is this possible?
I know that the '96 explorer has the 8.8 in the rear and the Dana 35 in the front. What exactly needs to done with the 8.8 to match the with the front dana 35? Is there welding involved? etc.?
If I use the the springs, I see they are over the axle. This would mean that I basically need a leveling kit instead of a suspension lift , correct? I have visited the James Duff(JD) web page and I see several suspension lift packages, but this is a budget build.
I also will be swapping the V8, transmission, wiring harness, and hopefully the dash from the explorer. I know that the JD website shows a 2" body lift that will be needed for the engine swap as well.
I appreciate you reading this and trying to help.
