96 Exp LTD odometer & speedometer don't work
tikki
1996 Explorer LTD
The check engine light is on & the code reader gave me a P0500, which indicates an issue with a speed sensor.
SoHK_alumni
Tampa, FL
5.0 V8 2002 Ranger
1st guess would be the VSS down at the back of the transmission.
Pretty inexpensive, easy to replace.
tikki
1996 Explorer LTD
Thank you, I'll look into it.
Flash
Brisbane Australia
1997 Limited
1996 model the VSS is at the back of the transfer case. Right at the output flange.
flash771
n. Idaho
1999 explorer eddie bauer
I have a 99 with no speedo and I already replaced the abs pickup on the rear diff any other ideas?
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Do you have a flashing OD OFF light, or check engine light turned on?
If not, your speedometer is dead.
Check all of your fuses, as there are 3 which protect the instrument cluster.
flash771
n. Idaho
Thank you I do have a code 32 ...I'll let you know how it goes.
Flash
flash771
n. Idaho
ok i have changed both the egr and the DPFE as per haynes and chiltons and still a code 32. Anyone know how to clear the code???
Mike65
Location
In my garage working on one of our vehicles.
Toms River, NJ / Horsepasture, Virginia.
00 Ranger 4x4, 99 Sport.
You could clear the code with a scanner, or if you unhook the battery for about 10-15 mins IIRC it should clear the code.
gatzdon
IL
2000 Exp XLS 4WD V6 OHV
Don't clear codes. That deletes information that could be helpful, especially if you recruit someone else to help. It also resets counters that could trip a DTC that would help you diagnose the problem (some problems have to be encountered a minimum number of times to set a DTC).
With an OBDII reader and Forscan, you can see the speed from each individual sensor. Could help you determine which one to look into. The issue may be wiring, not the sensor itself.
flash771
n. Idaho
The speedo was bad, replaced it now it works...Thanks Turdle
I still have a flashing air bag light...code 32
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
That is normally due to a bad connection somewhere in the clock spring.
Replacing the clock spring should fix this code. It is not as difficult as it sounds.
Just make sure when you begin, the steering wheel is centered, and do not move the steering wheel during replacement.
There are several you tube videos covering this.
flash771
n. Idaho
Now my windows stop working;....any body want to buy an explorer???
T 96 Exp LTD moon roof won't open or close Stock 1995 - 2001 Explorers 0
T 96 Exp LTD turn on OD Stock 1995 - 2001 Explorers 0
V 96 Exp Ltd - Cold Weather Driver's Window Stock 1995 - 2001 Explorers 0
E Best Shocks 2001 Exp XLT AWD??? Stock 1995 - 2001 Explorers 4
C repaired windshield crack on my Exp by myself Stock 1995 - 2001 Explorers 1
1 Replacing Fuel Pump in 98 Exp Sport V6 Stock 1995 - 2001 Explorers 2
Cuco WHY I JOIN EXP/FOR Stock 1995 - 2001 Explorers 2
D transfer case, 01 exp 4.0 L sohc Stock 1995 - 2001 Explorers 2
M Better? 1995 Explorer or 1999 Exp Xlt? Stock 1995 - 2001 Explorers 86
E To Buy or not to buy? 2001 Exp Stock 1995 - 2001 Explorers 2
H Painting 2001 Exp XLT rear bumper Stock 1995 - 2001 Explorers 9
C 1995 Ford Exp loud grinding noise while driving Stock 1995 - 2001 Explorers 7
M 96 exp - Shift Cable issue? Stock 1995 - 2001 Explorers 1
clackkent 1999 Exp Sport - end of life? Stock 1995 - 2001 Explorers 8
J Adding Keyless Entry to 97 Exp Sport Stock 1995 - 2001 Explorers 7
R 2000 4wd Exp, auto, 4.0 SOHC engine harness question. Stock 1995 - 2001 Explorers 2
D 01 exp 4.0 sohc. O/D Off light.???? Stock 1995 - 2001 Explorers 8
K 99' SOHV Exp. ....No Check Engine light on...rattle or tick on warm up (comes and goes) Stock 1995 - 2001 Explorers 13
A 97 Exp 4wd 4.0L V6 SOHC Shock Question Stock 1995 - 2001 Explorers 3
S 1995 exp 4l cel on Stock 1995 - 2001 Explorers 7
C 2000 exp transfer case Stock 1995 - 2001 Explorers 3
B Best Muffler for Stock 1997 Exp. Limited 5.0 Stock 1995 - 2001 Explorers 1
D I am going FULL manual 4WD running gear, will F150 hubs fit an Exp? Stock 1995 - 2001 Explorers 14
D How does the Control Trac system work - 96 Exp. Stock 1995 - 2001 Explorers 14
D '95 Exp EB - AC slowly stopped blowing through the front vents Stock 1995 - 2001 Explorers 0
K New Heads to Australia for 99 EXP VinX OHV Stock 1995 - 2001 Explorers 7
S 98 Exp Sport Door won't unlock and... Stock 1995 - 2001 Explorers 0
A 1996 Exp..I've change the ignition Spark Cables & A proplem Stock 1995 - 2001 Explorers 5
A 2000 exp 5.0 wont start Stock 1995 - 2001 Explorers 1
R new steering knuckes for exp 95 Stock 1995 - 2001 Explorers 1
J 1996 exp couple issues advice? Stock 1995 - 2001 Explorers 2
H 2001 exp sport v6, door locks & turn signal Stock 1995 - 2001 Explorers 1
B 1999 ford exp.sport Stock 1995 - 2001 Explorers 7
T 98 exp dies after running short time Stock 1995 - 2001 Explorers 0
G 98 Exp 4wd 4.0 Stock 1995 - 2001 Explorers 1
M 96 Exp Sport Steering issue Stock 1995 - 2001 Explorers 0
B 2000 Exp 4X4 possible transmission issue - bad in drive & reverse, but OK in 2 or 1 Stock 1995 - 2001 Explorers 2
F Need interchange for 99 Exp 5 speed trans Stock 1995 - 2001 Explorers 1
C Airbag replacement question f/97 Exp. Eddie Bauer. Stock 1995 - 2001 Explorers 1
J Oil in my coolant 99 EXP 4.0 OHV 4wd Stock 1995 - 2001 Explorers 11
W 1996 EXP Radio Stock 1995 - 2001 Explorers 4
A Rear climate console '97 Exp Stock 1995 - 2001 Explorers 1
J P1451 code on 2000 exp 5.0 Stock 1995 - 2001 Explorers 6
M Where to buy 8.5" Rear Cargo speaker-01 Exp Sport Stock 1995 - 2001 Explorers 4
M Troubleshooting 01 Exp Sport 4WD Stock 1995 - 2001 Explorers 1
C transmision problems are back again 97 exp. Stock 1995 - 2001 Explorers 3
W remaining life expectancy of '99 Exp 6-cylinder Stock 1995 - 2001 Explorers 27
P Dash Climate Control Out - Wiring? 2001 Exp Sport Stock 1995 - 2001 Explorers 12
W Need piks of 5L exp/mountaineer Stock 1995 - 2001 Explorers 0
C HELP: Not your normal Head Gasket issue, 99 EXP w/ 230K miles Stock 1995 - 2001 Explorers 5
Similar threads
