Hello all, new member first post with a question.
We purchased a 96 Exploder with the 4.0l V6 from the original owner that we know pretty well. It's in exceptional condition, but had been throwing a Cylinder 3 misfire code for the past few years, even though it did not seem to run any different.
They told her it might be something to worry about, but it also might be crappy gas as they didn't drive it very much. (literally only a couple times a year)
It was running fine when we picked it up, but within a month, set the code again, and then the kids started complaining that it had no power.
I replaced the plugs and wires, all the usual stuff, but the plug in cylinder 5 felt "bad"..kind of mushy and scary.., I'm almost afraid it's stripped or broken and I did not remove it. The cylinder is still firing normally.
I took it to a local garage that I trust for a diagnostic and they confirmed the Cylinder 3 misfire. They did not mention anything about cylinder 5.
They also confirmed, the spark plug is firing and the injector is working, leaving me to a potential broken valve spring or stuck valve....something along those lines.
The oil is clean, coolant is clean and it does not burn anything beyond a little oil that you would expect from 160k miles, so I don't believe I have a blown head gasket.
I'm left with the conundrum...do I just pull the heads and look into a rebuild/exchange since I'm having potential issues on both heads, or does this sound like it might be fixable in place?? I have worked on many vehicles, but am looking for thoughts from Explorer owners specifically.
How much of a PITA is pulling the heads on the 4.0 V6?
Thanks for any thoughts...
Paul.
Paul.
