Fortunately, C1194
does go out, once you replace the Hydraulic Control Unit, like kjtooltime mentioned back in 2010. I spent a big chunk of Saturday, trudging all over the local yard, looking for the cleanest HCU I could find in a similar year Explorer/Mountaineer. Being able to test the isolation and dump valve resistances on-site was very helpful in terms of identifying one that "should" work. Once I plugged the unit into my rig, the light was G-O-N-E. (Before I did any of this, I flushed all the old, filthy brake fluid out of the vehicle and replaced with new—didn't want to deal with all of this again, a week later, if I didn't have to...)
But... nothing has been said in this thread yet about how to bleed the HCU, once you replace it, since a standard brake-bleed won't necessarily deal with air in the HCU's valve body. Most of you probably know there's a special dealer tool that automates the process (some scan tools are able to do it, as well), but I was looking for a basic, DIY-friendly method. I started by doing a good bit of research on the "Teves Mark IV ABS System" and then came across a
thread on the SCCOA forum that pretty much nailed it. So, here's what I landed on to bleed the whole system, after installing the replacement unit:
- Do a standard brake bleed: RR, LR, RF, LF
- Do the HCU bleed process (see below)
- Do a final standard brake bleed: RR, LR, RF, LF
HCU Brake Bleed
- Unplug the replacement HCU's 2-wire motor connector and 8-wire valve connector from your vehicle's harness. Take the old wiring harness from the donor vehicle (yes, you need to cut the whole thing off at the JY and bring it home!) and strip about 3/4" off the end of each wire. Twist the two orange/yellow-stripe wires together (positive connection for all valves), twist the three small dump-valve ground wires together (orange, pink, and tan/red), and then identify the two large ABS pump motor wires: tan/red for positive and black for negative. You won't use the other wires; tape 'em off. Connect this "pigtail" to your HCU.
- Your (fully-charged) auto battery will be used to power everything. First, completely disconnect your battery from the vehicle and then, using a set of jumper cables or similar, connect the large black pump motor wire and the three dump-valve ground wires to battery negative.
- When you are good-and-ready and have rehearsed this a few times, start a 60-sec timer and immediately connect the large tan/red pump motor wire to battery positive. The ABS pump will begin running and building pressure.
- When 20 seconds have elapsed, and with the pump motor still running, connect the orange/yellow wires to battery positive to open the dump valves and hold in place for 20 seconds, then remove.
- Let the ABS pump motor continue to run for 20 seconds longer and then disconnect everything from battery. (Total run time for everything: 60 seconds.)
- Disconnect your makeshift pigtail and reconnect your vehicle's harness to the HCU. Reconnect your battery cables, and HCU bleed is complete.
