halfbakedj14
- April 13, 2010
- 96 explorer
I have a 1996 Ford Explorer 4 Dr Eddie Bauer 4WD. I am having a problem with my heat/air compressor I think. What is happening is that my compressor (or whatever switches from heat to cold located behind my glove compartment) isn’t switching over. Something that sounds like a flap or fan blade makes an annoying “clicking” sound behind where my glove compartment is. At first it did this for a few seconds then the “flap” would kick in properly and switch over to the heat or cold air, it kind of sounds like when a vacuum cleaner gets clogged then all of a sudden unclogs. But now the “flap” or fan blade won’t switch over at all and it is now stuck on heat and constantly makes the “clicking” noise. I was able to get the clicking noise to stop by disconnecting this white plug that connects to the compressor behind the glove compartment, which I later learned means that the air conditioner wont work while it’s unplugged which I guess doesn’t matter since the fan blade or whatever wouldn’t switch over anyway.
I begging someone to please help me at all if anyone knows what the problem is and could give me some advice. It’s getting hot and I want to be able to use my air. Thank you.
