mkee
- January 27, 2008
- Vancouver
- 96 EB
I drove to the mall yesterday and when I returned to start the truck it will not start, just cranks over. Had to call BCAA to check things out.
He went under the truck with a mallet and started hitting the fuel tank, while hitting I turned the key, it started.
He says its a bad fuel pump and should be replace asap, but when I started the truck today it started no problems.
I am wondering if I should replace the fuel pump or replace the fuel pump relay first to see if its the problem.
Thanks in advance.
Thanks in advance.
