Luft
- September 7, 2015
- Austin, TX
- 1996 Ford Explorer
1996 Explorer AWD 5.0 V8
So Ive had this project now for what seems like forever. And I finally got it running right. Now I'm just wrapping up a few odds and ends.
One of these odds, is whenever I bring it up to 60 I can feel it start to shake a little. I can feel it even worse if I bring it to 70 and let it engine break. You can feel it whenever you put the front axle under load.
So I went and got some of the basics done tire rotation, tire balance, and an alignment. And it helped a bit but the problem is definitely still there.
So I decided to take a peak up underneath to see if I could see anything. I also just had a gut instinct it could be the front driveshaft. (I had just replaced the front driveshaft and transfer case.)
While I was under there I noticed that the front driveshaft tends to shift up and down while in gear and spinning. I noticed that the u joint straps connecting the front driveshaft to the front axle, I noticed that I could see some daylight between the straps and the driveshaft.
I don't think thats normal but it could just be me being paranoid. The only other thought is that the front driveshaft could be bent. Which is a major bummer since I bought this driveshaft new and it took me a month to find it.
Any thoughts would be greatly appreciated.
