96 Explorer wont start | Ford Explorer Forums - Serious Explorations
jsepps
houghton
96 explorer
It ran fine the other morning on the way to work but when I tried to start it after work it wouldnt fire at all
It turns over good and has good spark so I think it might be a fuel issue
Any ideas?
Fuel pump relay
Fuel Filter
Fuel pump cuttoff or "inertia "switch
Fuel pump
When you first switch the key to "on" do you here an electric motor noise near the fuel fill area?
Fuel pump relay
Fuel Filter
Fuel pump
Its not the cuttoff
Its next to a busy 4 lane highway so I cant hear very well there. I will go back later when traffic dies down to see if I can hear then
Fuel pump failures are quite common, especailly in warm or hot weather. See if you can find the fuel pressure test port on the fuel rail, looks like a tire schrader valve. Push on the center and see if fuel squirts out of there, if not then yes you have a fuel problem.
thanks
This sounds just like my 96. Did you get the problem pinpointed?
Not exactly. I sprayed some starting fluid in the intake and it did fire up until I stopped spraying. I got a fuel relay and a filter coming tomorrow
where is the fuel relay located?
I finally have some time to look at it tonight. Could someone please tell me where about where the fuel pressure test valve is?
