96 sport ,, lift? or throw tires on??
dtl 2k2 sport
stafford Va
2002 SPORT
I have a 96 SPORT,, 4x4,
i would like to throw some 33's under that sob, but dont really wanna go through the effort of throwing on a body lift. If i put some 15x10.5/ or 12.5 rims would i get by w/ out having to lift or mild trimming?? ooooooR
would i need to lift it and deal w/ that mess? Thanks ,, i tried searching but havent had any luck.
Thanks for the insight,
Dave
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
i have 33's on mine, with no cutting so far , it wasn't easy , and it was not cheap, but it can be done,,
how did i do it ?
suspension lift , and the wheels and tires,
if you want to go a bit bigger in the wheel and tire department, there is a way to lift it for cheap high enuff for 31 inch tires,,
dtl 2k2 sport
stafford Va
2002 SPORT
31's will fit fine, i had a set on my old explorer sport, stock , but im trying to avoid doing the body lift, and deff not spending money on a suspension lift. I was just wondering if it could be one w/ out going those routes, body lift would deff be cheaper, but still a lot of labor. Thanks for the info fellas!,
D Rear Lift issues on a 2000 Explorer Sport Shocks, Suspensions, Lift Kits 2
F 2001 Ford Explorer Sport Lift? Shocks, Suspensions, Lift Kits 3
K Do I need a longer rear drive shaft, After 4 inch lift on a sport Shocks, Suspensions, Lift Kits 7
T Sport Trac Spindle Lift Shocks, Suspensions, Lift Kits 21
L 2002 Ford Explorer Sport BODY LIFT???? Shocks, Suspensions, Lift Kits 1
R Will a Ranger lift kit work on my Sport Trac? Shocks, Suspensions, Lift Kits 1
R 2001 Explorer Sport lift. Shocks, Suspensions, Lift Kits 13
W 1997 Explorer Sport. I want to lift it. Shocks, Suspensions, Lift Kits 7
C 2000 explorer sport lift Shocks, Suspensions, Lift Kits 0
A I need lift advice for my Sport Trac. Shocks, Suspensions, Lift Kits 4
J I want to lift my 2003 Explorer Sport. Shocks, Suspensions, Lift Kits 13
C Body lift for a Sport Trac. Shocks, Suspensions, Lift Kits 1
1 Lift for a 97 Explorer Sport Trac with 4WD. Shocks, Suspensions, Lift Kits 8
Govna47 Body Lift 2001 Explorer Sport Shocks, Suspensions, Lift Kits 3
F do they even sell a lift for a 2001 explorer sport i cant find one anywhere Shocks, Suspensions, Lift Kits 6
W explorer, ranger, sport trac lift kit differences Shocks, Suspensions, Lift Kits 2
T '98 Explorer Sport Lift wanted Shocks, Suspensions, Lift Kits 0
C Use a 97 ford ranger sus lift for a 97 explorer sport 4x4? Shocks, Suspensions, Lift Kits 1
9 93 Sport Lift Shocks, Suspensions, Lift Kits 0
N 2001 Explorer Sport Lift (Help!) Shocks, Suspensions, Lift Kits 0
G 97 Explorer Sport - shock and lift questions. Shocks, Suspensions, Lift Kits 2
ProjectAviator SOA with 2 sport springs on a 4 door = how much lift. Shocks, Suspensions, Lift Kits 1
dislexiclawyer 2" lift on a 92 Sport Shocks, Suspensions, Lift Kits 4
T 03 Sport trac with ranger lift ????? Shocks, Suspensions, Lift Kits 7
H 98 Explorer Sport lift question Shocks, Suspensions, Lift Kits 8
B How to lift an Explorer Sport Shocks, Suspensions, Lift Kits 5
J 91 sport lift Shocks, Suspensions, Lift Kits 0
C Lift Option for newbie, 99 sport 2wd Shocks, Suspensions, Lift Kits 0
P got my self a 2000 sport manual i want to lift Shocks, Suspensions, Lift Kits 10
9 97 sport needs a lift Shocks, Suspensions, Lift Kits 1
T Lift Questions, 2WD - 99' Sport Shocks, Suspensions, Lift Kits 21
R HELP!! 00 SPORT NEED Lift Shocks, Suspensions, Lift Kits 1
X HELP!! lift on '01 exp sport Shocks, Suspensions, Lift Kits 7
P 07 Sport Trac lift kits? Shocks, Suspensions, Lift Kits 1
C 99 Explorer Sport Lift Shocks, Suspensions, Lift Kits 8
L Want to learn how to lift an Explorer sport Shocks, Suspensions, Lift Kits 16
B lift kits for 01 sport? Shocks, Suspensions, Lift Kits 3
G Sport Trac Lift??? Shocks, Suspensions, Lift Kits 8
9 2wd 05 Sport Trac lift?? Shocks, Suspensions, Lift Kits 3
L 01 2wd sport trac lift kits.... Shocks, Suspensions, Lift Kits 6
S 01 Sport cheap lift...Shackles and a leaf??? Shocks, Suspensions, Lift Kits 14
C 2001 Sport Body Lift Shocks, Suspensions, Lift Kits 1
7 front lift options for a second gen sport? Shocks, Suspensions, Lift Kits 1
T body lift for 99 sport Shocks, Suspensions, Lift Kits 2
O 2-3" lift for a 2001 sport 4x4 Shocks, Suspensions, Lift Kits 1
2 3" body lift 0n my 2000 ex sport Shocks, Suspensions, Lift Kits 2
97awdx What is the best body lift for a Sport Trac? Shocks, Suspensions, Lift Kits 2
9 '97 sport body lift ? Shocks, Suspensions, Lift Kits 10
B desperately need 6" lift kit for 97 sport Shocks, Suspensions, Lift Kits 11
E Lift Needed for Explorer Sport Shocks, Suspensions, Lift Kits 29
Similar threads
