96 XLT won't start | Ford Explorer Forums - Serious Explorations
96 XLT won't start
skipr
Western Massachusetts
96 XLT
Last week truck wouldn't when my wife was leaving work. When she went back the next day it started right up, and ran great for a little over a week. This morning it again wouldn't start. So I go out and try to start it up, I don't here the fuel pump cycle as usual, so I swap one of the relays to the fuel pump in the distribution box under the hood. Still nothing, does this sound like it could be a fuel pump?:(
Thanks for your help, Steve
It does. The pump isn't all that hard to change.
Welcome to the forum.
edit--does the check engine light illuminate when the key is switched to "on"?
Not sure about the check engine light. I will have to check in the morn. as I am at work. What would that indicate?
If the PCM isn't on, then the fuel pump won't be switched on. If the check engine light comes on , the PCM is powered .
if not, check the PCM relay.
Thanks for the info I will check that in the AM;)
Got home this morning, while turning over the engine I wacked the fuel tank wuth a rubber mallet, and what do you know it fired right up. Then quit again. Definatly the fuel pump?:(
