wesalexleft
- August 2, 2009
- Memphis, TN
- 2003 Mountaineer V8 4.6L
I need to replace the rack/pinion on my 1997 Mountaineer with a 5.0 V8 and rear wheel drive. I also have an oil pan gasket leak. I'm wondering if I can get the pan loosened enough to work on a new gasket with the rack removed and not have to unbolt exhaust and without raising the engine. I've seen some threads saying its doable, but others saying the pan is different on the 97 models, and others saying it can be done on 2wd, but not AWD.
Anybody done this? No lift available, just ramps and stands. It's leaking pretty good, so while I have the rack out, if it's possible, I'd like to do both. The rack has play at the ends making a knock on small bumps at neutral steering.I don't know if I have the one piece rubber pan gasket, but had seen where some people were able to cut the original to remove, and then bend the new gasket around the pan and into position.
thanks,
thanks,
