xnewengx76
- December 12, 2005
- Rocherster NY
- '97 Eddie B.
Hey guys, I read often but don't post too much, but I need to today!
On my way to school this morning, my temp gauge went past the 75% mark, and my heat went away. This has happened to me before, I have been loosing coolant at a steady rate (nothing serious) and had forgot to top it off that month. When the engine is run between 2k to 3k, the gauge usually shoots right back down. It happened again for the first time in a while, while is was stuck bumper to bumper, and wasn't able to lower it by running up the engine RPM (and I also didn't want to increase the engines heat by doing that too much). I finally made it to my destination, and as I was pulling in steam came pouring out of my hood. I opened it up and found what seemed to be a leak coming from the passenger side of the radiator, below the upper hose.
It may have been the hose, not sure. But I am assuming that I was low enough on coolant to allow whatever was left to turn mostly into steam, thus increasing the pressure enough and blowing through what was probably the small leak I have been fighting for a while.
Sorry for the long read, just making sure I include the details.
What suggestions do you all have in order to fix this? I have used Bars before (last year), and it since stopped the leaking almost 90%, until today.
Thanks for you help.
