Selling my 5.0 long block as I've built a 347 for my Ex. It has 121k miles on it, used Mobil 1 oil and has been changed regularly. The timing chain is surprisingly tight. Uses no oil, and runs great. Can be used as is, or rebuild it. What you get: Block, rotating assembly, roller cam, lifters, pushrods and rockers. Harmonic balancer and good flexplate. I will also include the exhaust manifolds if you want them.The heads are still bolted on, so you would have to add the intake, oil pan, a new oil pump, timing cover and I will also include a fairly new water pump. $350.00 and I would prefer local pickup. I'm outside of Mooresville, NC, 28117.
