97 5.0 V8 Freeze plugs rotted out | Ford Explorer - Ford Ranger Forums - Serious Explorations
FR3D
1997 Explorer Limited
Bought the car as a project recently
It's a limited AWD 5.0 v8
just wondering how much one would charge to replace all the freeze plugs around the engine
does this require pulling the engine?
Should sealant be applied ?
And pretty much I just want a rough estimate of what I'm looking at
Also I'm wondering if anyone here has a diagram of the area I'm referring to
Thanks , I read this forum constantly since I got the vehicle , just made the account also
96eb96
Albany, NY
96 EB V6 OHV 4WD
You may want to look into copper screwdown freeze plugs. I replaced some of mine and they hold up very well. Locktite red may be a good choice for a sealant. Be careful not to scratch the bores when removing them. Heard that RTV could make things slippery, just relaying what I read on the net. Probably fine to use.One of the machine shops here uses them for people who want to drain the block easily. That is how I found out about them. If you can see the plug you can get it in, not sure about the v8 though.
http://www.dormanproducts.com/c-353-expansion-plugs-quick-seal-copper.aspx
FR3D
I need a diagram of the expansion/freez plugs if anyone out there has one
its a v8 5.0 limited trim
i sealed one but i cant figure out where the other leak is coming from but its dripping towards rear-center of the engine
im sure its another plug as they are all rotted out im trying to see if i can temporarily fix itto drive short distances ( 4 miles a day )in the meanwhile
