tokenrock
- August 4, 2013
- 1972 Bronco
I've swapped a 5.0 and 4r70w trans from an Explorer to my 72 Bronco. I kept the entire engine and trans harness intact, but cut the wiring from the C115 to body. I'm now trying to connect the C115 to main body harness on the Bronco. I've tried wiring the Power and grounds on the C115 connector, but can't get the engine to start.
Does anyone know what the minimum connections are required to start the engine? I have the fuel pump on the main harness relay circuit, so it's not attached to the computer.
