There's a leak in my evaporator and i need to replace it. Can anyone sart me in the right direction to locating, removing, and replacing it? It would be much appreciated
Did it recently. Seems like its somewhat of a common issue. Like the other posters said, but you have to take off 4 nuts, one is by the passengers right foot above the carpet, the other 3 are in under the hood. Two you can see in his picture. (one over the blower the other by the heater hoses). The third is a major pain in the a#$. it is about a foot or so below the one by the heater hoses. Get a step stool and be prepared for some shoulder spraining.
Remove the coolant bottle/cruise/move all the wiring aside, be careful about the vac lines. Carefully remove the heater hoses, use a curved tool to break the seal on the heater core line. Please don't pull on them or you will have a heater core job.
You can seperate the AC fittings with the seal from an oil bottle, cut it to the circumference of the A/C line and push it into the garter spring. You have to play with it a bit to displace the spring. There are also tools for this.
See
www.ackits.com
Replace your Accumulator, NEW Orifice tube, and evaporator, and o rings disturbed.
DO NOT FORGET THE ORIFICE TUBE IN THE EVAP!!!!
He has great prices on the components, and they have great service (satisfied customer)
Also look at this thread, make sure you add plenty of oil. NYLOG is a great idea too.
http://www.explorerforum.com/forums//showthread.php?t=217729
This is optional:
If you can, replace your blend door. It is a 10 dollar part from napa, its possible (but a bit awkward) to get it into the plenum. Take off the actuator from inside the truck, you can do it with a screwdriver and prying it off the clips.
Go under the hood, and Take the old door out with a pry bar from the bottom or top, cut off a bit (1/4" or so diagonal) of the new door, the lower corner facing the front of the truck and try to get it back in. Its no fun but the blend door will break eventually and you will have more headaches.
Dont forget splash safety glasses if you charge the system!
