musician235
- April 10, 2013
- Bethel, AK
- 1997 Explorer
I can't solve the high idle issue and am wondering if there are any other things I'm missing.
I've checked for vacuum leaks, replaced the TPS, IAC, Coolant Temp Sensor, reset the computer by disconnecting the battery, cleaned the MAF Sensor.
The IAC wires are getting correct voltage, but there is no change in idle with or without the IAC connected.
With the Maf Sensor disconnected the car idles under 1000 but there is no throttle response.
The throttle cable is not stuck and I turned the screw on the arm all the way out to lower as much as possible.
Thanks in advance.
Thanks in advance.
