Beargap
- May 27, 2008
- Bear Gap, PA
- '21 XLT
- Callsign
- WA4THR
Our '97 SOHC 4.0 with 297K miles has started missing irregularly. It starts easily enough, but never settles down to smooth running. Had the CEL come on in below-zero weather code, so I read and it was Lean bank one and two. We sprayed cleaner into the MAF port and cleared the code by disconnecting the battery. It continued to miss, although maybe slightly better, but in single digit weather a few days later the CEL came on flashing, then settled down to steady on.
I believe the truck is pretty overdue for new plugs, so we're looking at that, but what does the flashing CEL mean at the beginning? How do you get the MAF out of the plastic housing so we can clean or replace it? Anything else we should be looking at?
