kartbrown
- June 26, 2009
- Northwest Ohio
- 1997 Ford Explorer
I have a 1997 Ford Explorer that will not move if I am below 10mph in drive. When it first happened I backed out of a parking space and shifted into drive. When I accelerated, the Explorer jumped a little, it sounded like something crunched or popped and then the engine just revved when I accelerated. I then shifted down into 2nd and it drove away. I drove home slowly in second.
I only work about 1.25 miles away from work so the next morning I slowly drove to work. Well, on the way home, I was driving in 2nd and I shifted into drive. To my surprise, it kept driving and shifted through the gears as I sped up. I thought this was a little relief because it does not seem to be as bad of a problem as I previously thought.
If I slow down or come to a stop, I must shift down into 1st or 2nd to get started and then once above 10mph, I can shift it back into drive and it will shift through the rest of the gears like normal.
Any thoughts as to what the problem may be?
Thanks!
Thanks!
