97 Explorer wont crank | Ford Explorer - Ford Ranger Forums - Serious Explorations
jeffs_explorer
Fieldale, VA
97 XLT
I have a 97 Explorer that will not crank. It turns over, but will not crank. I have changed the battery, the fuel filter, the throttle position sensor, and put a new power pack on it. I need any advice I can get.
budwich
Ottawa, Ont
96 XL
Just a small note of "terminology correctness". "Cranking" means the activity of having the starter engage and cause the engine to "turn over". "No cranking" usually means "quiet" as in nothing happening outside of maybe "clicking" of relays. SO.... if I understand correctly, your engine is "turning" but not "firing" (ie. action of explosions in the each cylinder) for some reason. You need to determine IF your fuel pump is running by either listening for some "noise" of the pump action just after turning the key on AND / OR checking for fuel pressure in the fuel rail. If you got fuel, then you need to determine if you got spark by checking a spark plug.
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
No Mounty no more.
Could be the fuel pump called it quits.
Spray a little starting fluid in to the intake duct. If it fires then stops it's a fuel problem.
jeffs_explorer
Fieldale, VA
97 XLT
How do you check the fuel pressure in the fuel rail?
MakinJeepsWeep!
Polk County Texas
96 Explorer 5.0L AWD
Callsign
Big Red
What is being considered a "power pack"?
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
I guess just because it's under what's new it isn't always new haha
Pete Deering
New England
1995 xlt 4 door 4x4
Check the Inertia switch. Its located at the passenger side kick panel (inside car). The red button top should be even with the top of the holder top ( fuel pump on). When it off ( disengaged), the red button is above
