97 Ford Explorer XLT 2WD 5.0/Clutch Plates
Status
Not open for further replies.
Chrisrod2016
Location
Texas
San Antonio, tx
97 Explorer XLT V-8 5.0
Yesterday I changed my clutch plates and left rear axle. There is a slight humming at certain speeds. Is this a common thing to hear until the new parts get broken in?
  • Like
Reactions: imp
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@Chrisrod2016
Was the tooth contact pattern between pinion gear and ring gear checked and corrected if needed?
imp
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Please don’t start a new thread for every question you have on the same topic.
Status
O 2002 ford explorer v6 xlt drivetrain thumping Transmissions & Transfer Cases 0
K 2003 ford explorer sport xlt slipping in drive/reverse Transmissions & Transfer Cases 1
M 2002 Ford Explorer XLT P0775 error.. no check engine light Transmissions & Transfer Cases 20
A 05 Ford Explorer XLT Transmission leak... Help Transmissions & Transfer Cases 2
K Help: Ford Explorer 2014 XLT 4WD got towed from the front in the parking gear! Transmissions & Transfer Cases 4
H 2004 ford explorer xlt want move in drive Transmissions & Transfer Cases 1
S "OD Off" Light, 1999 Ford Explorer XLT 165k miles Transmissions & Transfer Cases 1
9 1996 ford explorer xlt awd v8 tranny question Transmissions & Transfer Cases 2
N 2001 Ford Explorer XLT - 2/3 Shift Flare - Need Answers Please Transmissions & Transfer Cases 14
D 1999 Ford Explorer XLT. 4 wheel drive doesn't work. Transmissions & Transfer Cases 1
H Ford Explorer 1997 XLT transmition problems Transmissions & Transfer Cases 0
4 4WD issue in my 1996 Ford Explorer XLT. Transmissions & Transfer Cases 8
F 1994 Ford Explorer XLT with an automatic transmission problem. Transmissions & Transfer Cases 13
R 1994 Ford Explorer XLT with A4LD transmission problems. Transmissions & Transfer Cases 8
P 2002 Ford Explorer XLT with a flashing O/D light. Transmissions & Transfer Cases 52
P 1998 ford explorer v-6 xlt popping and clunking problem Transmissions & Transfer Cases 0
A Ford Explorer 92 XLT with a code 629. Transmissions & Transfer Cases 71
K 1994 Ford Explorer XLT-4WD Not Engaging Transmissions & Transfer Cases 6
M 2005 Ford Explorer XLT Noise while in 4WH Transmissions & Transfer Cases 0
T drive shaft installation 98 ford explorer XLT Transmissions & Transfer Cases 5
P can anyone help me 91 ford explorer xlt Transmissions & Transfer Cases 2
A 1992 ford explorer xlt transmission Transmissions & Transfer Cases 0
D Transmission/Transfer case problems!! :( 97 Ford Explorer XLT 4.0 V6 Transmissions & Transfer Cases 7
S 2002 Ford Explorer Transmissions & Transfer Cases 2
C 2004 Ford Explorer transmission. Options? Transmissions & Transfer Cases 3
C 2000 ford explorer sport clutch hydraulic line problem Transmissions & Transfer Cases 2
A 08 Ford explorer limited transmission question Transmissions & Transfer Cases 0
1 1998 Ford Explorer Manual Trans: Bleeding Master & Slave Transmissions & Transfer Cases 2
R Will a transmission from a 4.6 ford explorer work in a 4.0 explorer? Transmissions & Transfer Cases 4
M 2002 Ford Explorer Transfer case housing gasket. Transmissions & Transfer Cases 9
C What years will Ford explorer 94 transmission interchange? Transmissions & Transfer Cases 1
D At a lost . I have a 2005 Ford Explorer with the advancetrac system have four things wrong with this Transmissions & Transfer Cases 2
A 1991 ford explorer transmission problem Transmissions & Transfer Cases 1
N 2007 Ford Explorer 4.0 Shifting Hard Transmissions & Transfer Cases 0
E 2004 Ford Explorer 5R55S shifting problems Transmissions & Transfer Cases 1
R 04 ford explorer transfer case Transmissions & Transfer Cases 0
N 2014 ford explorer transfer case removal ? Transmissions & Transfer Cases 0
J Ford Explorer OHV 4l OD Light flashing! Transmissions & Transfer Cases 10
J Ford explorer Transmissions & Transfer Cases 3
O Transmission and Thermostat Housing Unit-1997 Ford Explorer Transmissions & Transfer Cases 0
M M5OD-R1 HD swap 1994 ford explorer Transmissions & Transfer Cases 7
0 2002 Ford Explorer started slipping. How long could it run before it's dead? Transmissions & Transfer Cases 7
C PLEASE HELP transfer case advice 2007 ford explorer limited v8 4x4auto Transmissions & Transfer Cases 0
J 2002 Ford Explorer Sport - Potential Transmission Problems Transmissions & Transfer Cases 1
T 2004 Ford Explorer Transmission issue Transmissions & Transfer Cases 2
K 2005 Ford Explorer Transmissions & Transfer Cases 3
H 03 Ford explorer tranny help!! Transmissions & Transfer Cases 5
S 2002 Ford Explorer 4x4 4.6L automatic Transmissions & Transfer Cases 1
J 01 Ford Explorer wont drive in reverse nor drive, only 1 & 2 gear Transmissions & Transfer Cases 2
S 2005 Ford Explorer Trans Problems Transmissions & Transfer Cases 0
Similar threads
