monty98
- October 1, 2018
- 1998 Mountaineer 5.0 AWD
I've looked as researched before but seem unable find this time.
I have issues with the fuze #10 blowing & have thread about trying find cause already but haven't had success. Haven't had much time to search for cause though.. Speed control & overhead console plus the blend door actuator are on this one. I'm investing in a ton of 7.5 fuses to hopefully get me through winter unless cause is found. However, wondering about what is hopefully an easier to resolve problem.
Issue. The directional controls & fan settings work fine. Heater blowing full hot no matter setting on the hot/cold dial. Then it just started blowing only cold air...discovered fuse had blown again. I've replaced the fuse again & get heat but no temp control turning the knob--it is furnace heat even if turned to cold. When I replaced the actuator earlier this year door seemed fine. Is this likely a blend door problem or issue with the actual manual control or ? Is there a way to narrow down the problem?
If there a thread already just point me to it.
Thanks
Thanks
