'97 mountaineer axle swap | Ford Explorer - Ford Ranger Forums - Serious Explorations
acabtp
Morris County, NJ
'97 Mountaineer AWD
i am swapping rear axles (3.73 lsd) on my '97 mountaineer (v8 awd).
old part is a S621A 3L73 88 7A23 with lots of carrier bearing noise
"new" part is a S621E 3L73 88 9B06 from a lower mileage donor
everything I can find says that they are interchangable and things are bolting up so far, but I just wanted to double check.
acabtp
Morris County, NJ
'97 Mountaineer AWD
Follow-up question:
Are there any bright ideas to remove the lock bolt inside the old differential? It is really on there and it is starting to get stripped. I have soaked it in penetrant, heat cycled it a few times with a torch, tapped it with a punch, but it still won't budge. I am about to use a cutoff wheel to slice into the locking pin where the bolt goes into it, but that will take a while and be a mess. I thought about welding an 8mm socket onto the bolt, but I did not think I could get a good weld in such tight quarters or with all that old diff lube.
I do not care about the rear end it is being removed from, I just need to get the axle shafts out so that I can swap the dust shields and caliper brackets to my replacement axle.
acabtp
Morris County, NJ
'97 Mountaineer AWD
well, i got the lock bolt removed. in case anyone finds this in the future by searching: i ground the end down on an 8mm socket to remove the chamfer so that it could get a grip as far down on the head of the bolt as possible. came out no problem.
acabtp
Morris County, NJ
'97 Mountaineer AWD
Also, for anyone searching in the future... the S621E rear axle (from a '99 mounty) was a direct swap for the S621A that came in my '97 mountaineer.
No more ridiculous noise! Problem solved!
