Hi all,
I know this thread is somewhat defunct, but in case anyone is still here: My dad and I are also doing a 1997 Ranger Conversion. 96V with deep-cycle lead acid batteries, and batteries in a welded rack underneath the bed so the bed can still be used (we put a hinge on the bed so it can be lifted easily). I'd be happy to post some pics once we're done. However, we've run into an issue that the owner of this thread apparently also had with the speedometer, and hopefully someone (maybe even Jim Martin?) can offer some advice.
The Vehicle Speed Sensor is supposed to connect to the Powertrain Control Module. However, when we removed the engine, we also removed the PCM 104-pin harness (we still have the module itself). Does anyone know if it is possible to reconnect the necessary pins, and if so, would the PCM need a source of power? Or doe the wires from the VSS also have to pass through some other circuitry to make it work?
Appreciate any input we get!
