97 rough idling | Page 2 | Ford Explorer Forums
97 rough idling
aldive said:
Here are several things to do that should help the idle:
clean the MAF
clean the IAC
run a can of Sea Foam through the intake
Good luck .....
Hi there.
I haev a 2000 XLT SOHC. I seem to have a problem with the IAC, which I will be checking shortly, per suggestons from others (stalls when idling). I've seen mention of this MAF, and sea foam. What is MAF, and how to do test/repair/replace, and what is Sea Foam, what does it do, and how is it applied.
Thanks!
athertonwj said:
Hi there.
Thanks!
MAF = Mass Air Flow sensor.
Seafoam - take a look at this thread http://www.explorerforum.com/forums/showthread.php?t=120853&highlight=sea+foam
Cleaning MAF - take a look at Dead Link Removed
I'm having the shaking at red light issue also, MAF, IAC, TPS and Spark Plugs are fairly new. Any suggestions?
I think most of the original posters have died of natural causes by now.
Lol.. cept Aldive.. Any suggestions though?
Is your problem only at idle? Checked vac hoses?
I checked the ones I know of.. I think.. You're talking about the very extremely thin rubber hoses on the driver's side front? Do you have any diagrams of the system? I used to have a bunch but they were all lost when my flash drive took a crap.. =\
idle speed might be too low. fuel injectors.
