cherrington
- November 14, 2009
- lockport, ny
- Its a '97 "?"
It appears to be leaking directly from the forward most part of the tranny pan, and is dripping down onto the cat (causing smoke and bad fumes)
I looked on rockauto and found these part numbers...
WIX Part # 58841 More Info {Transmission Filter #FT1087A} 4WD
ACDELCO Part # TF302 More Info {#25313823}
FILTER KIT,A/TRNS FLUID 14 HOLES, DEEP PAN; 4R70W TRANS, 4 SPEED
MOTORCRAFT Part # FT103 More Info {#3Z9F593DA, F5TZ7A098B}
4WD; Trans. code 5R55E
its a 4 speed auto. How do I know which I need. And those are the filters... do the tranny's not have a gasket? Or did I just manage to miss that somewhere?
