Lonnie-S
- August 10, 2012
- Carlsbad, California
- 2002 Sport Trac 4x4
I've been trying to understand exactly what I'm getting using the various 4x4 modes in my truck. It's an XLT with SOHC, 4.0L V6 with automatic transmission and 4.11 limited-slip rear axle. I assume the front differential is 4.11 too, but the open type. Maybe others have the same question(s) in their mind. Here's what I think I'm getting. I could very well be wrong.
4x4x Auto: It's really in 2-wheel, rear drive, but if the system senses a loss of traction on the rear wheels, power is sent to the front differential via the transfer case. If that's right, how does it "sense" the rear axle loss of traction and what logic (percent of power to transfer, for how long, etc.) is used to make this happen and which vehicle component makes the decision?
4x4 High: Power is supplied to both front and rear differentials all the time. If so, what percentage goes to the front and rear? Is the percentage changeable by the 4x4 system dynamically as conditions change or is it always fixed?
4x4 Low: Same as 4x4 High, but uses low range gear of transfer case.
Secondarily, I'd like to know if a locking differential at front or back, or both, would be compatible with the stock 4x4 system or just cause problems. In particular, is it possible to "lock" a limited slip differential at all? Has anyone had experience with lockers on an otherwise stock 4x4 system?
Thanks,
Lonnie
Thanks,
Lonnie
