'97 XLT Dana 30 SAS
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
Well since I don't have the time/tools/skills to build my own, but I do have the money, this isn't going to be a build log, just show the final product since I don't have much for "during" pics.
Dana 30, trussed and gussetted. 4.56 gears, Eaton Truetrac (front and rear), SOA with Chevy 1500 63" leafs, 1354 manual transfer case, F-150 steering box.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
That sits REAL nice, and flexes quite well! What size tires are those? How about a couple closeup pics of the front axle, like the trussing and gusseting?
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
Sure. I'll take some more detailed pics and post them over the next couple days. Taking it wheeling this weekend so I'll get a chance to test it out.
Black99Snake
semmes, al & colorado springs, co
2000 ranger 4x4 4dr
how do you like the swap so far? ive been thiking about doing the dana 30 swap here lately. who did the swap for you?
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
Swap is great so far. I've taken it on a very difficult trail (Chinamans Gulch) and just got back from a weekend of "expedition" style (road, 4wd trails, camp, 4wd trails, road, 4wd trails, camp.....) and it was very civil. It goes pretty much where I point it- up and over big rocks, through some snow......
The guy that built Merc, Lazy Boy, Rock Ranger, Snoball and a few other rigs built mine. He's up in Parker- maybe an hour from you.
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
Always been a fan of your setup. Got a picture of the front spring mount for the Chevy's. Haven't seen many explorers with the longer springs.
Styx
Chilliwack BC Canada
02 eddy 93&13 limited
Looks really nice any Idea what the front springs are out of???
rabbit91
Surrey
2000 V8 lifted 33s
bump looks nice and inspiring, hows the dana 30 holding up and is it a HP out of a ???
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
The D30 is out of a 96 Cherokee.
It's holding up great. The D30 + Truetracs = it goes where ever I point it.
On the road it's good. My turning radius isn't the best since my sway bar hits the sidewall of the tire. It's pretty softly sprung (and its so tall) so it can sway a bit but it's not too bad. I've since added some quick disconnects for the swaybar to make that easy.
Thompson1995
Senoia georgia
1998 Ford Explorer
What size jeep coil springs did you use?
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
Initially it had Rubicon Express 5.5" lift XJ springs and now it has Iron Mountain Offroad ZJ springs with about 2 coils removed to give it the same ride height and significantly stiffer spring rate.
The RE springs were too soft. Bumps on the road were scary as it bounced all over the place. On the trail I would come off an occasional rock or something and it would bottom out. And I wasn't going fast. I somehow knew it was under sprung and not under damped. The ZJ springs have improved everything.
derelict
Fords,
Were the Chevy leaf packs stock ones? Also, what is the belly height on this? I like it as it seems to sit a lot lower than other conversions? You never mentioned what size tires you are running.
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
The Chevy 63s are stock 1500 springs (1/2 ton). They will be swapped out soon for some 2500 springs (3/4 ton) springs.
Tires are 33x12.5r15. At some point I will upgrade to 35x12.5r15.
derelict
Fords,
Great. Do you by chance have the belly height? Like, distance between ground and frame?
rabbit91
Surrey
2000 V8 lifted 33s
What size ZJ springs ?
derelict
Fords,
Thats great. Yours seems to sit just right. It is not a monster truck, which is what I would be going for. Something low with 35s. The Chevy springs seem to work really well. Stock shackles?
Would love to hear about the belly height. Does it feel tippy at all when going into camber stuff?
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
