97 xpler xlt 4wd 4.0 sohc help | Ford Explorer Forums - Serious Explorations
jarheadbill
Whittier Ca
97 ford explorer
I'm trying to figure out what fluids I need for front , rear diffs and transfer case ??? And if I need an additive ??? Also how do I know what tranny I have so I can get the right filter and gasket ??
Any help is greatly appreciated !
SEMPER FI
You can use the same trans fluid in your transfer case (Mercon 5) as your trans. I'm unsure about about the diffs but I'll find out as my front has been leaking badly from the pinion seal for some time and will need to be topped up when I replace the seal.
Edit: If you have an auto trans it's a 5r55e.
