98 2wd coil sup ball joint (lower) | Ford Explorer Forums - Serious Explorations
jdjethro
spooner wisconson
98 ranger
do i really have 2 replace the lower control arm to replace my ball joints the truck has 60xxx so i know they are original and the parts store sells the ball joint but says for the first one i must replase the whole lower arm
No, you can replace the lower ball joints seperately. Upper ball joints are the ones that require new control arms. You should be able to press the old ball joints out of the lower control arms with a ball joint press.
