Justin_
- March 30, 2020
- Missoula
- 98 2-DR Sport 4x4 4.10
- Callsign
- KJ7IKI
Ive been poking at my rich codes for a while now, and this is not the first time ive posted about them, but I think I finally distilled all of my issues down to one photo.
This is Fuel PWM and O2's for bank 2 on top and bank 1 on the bottom. The first part is warm engine at idle with AC on, second half with AC off.
Bank 1 on the bottom is looking ok enough, but bank 2 on the top has something crazy going on there. The sensor shows it as rich, and the computer knows that, but its still feeding it twice the fuel as bank 1!
Is there any explanation as why this would happen?
Other issues include occasional hesitation at acceleration from stop and BERO reading being much too low. Its not bad today, reading at 27.4 when it should be closer to 29.8 (read off an actual barometer, not from weather service). However, at times it reads as much as 10 inHg off from what the accurate reading is.
Only other interesting thing to know is the drivers side cat is cut off and there is a flex line there instead.
I was reading over the documentation for the EEC V code today and did find this graph
It almost looks like im in the midbed overtemp protection mode, but I dont have access to any PID to confirm or deny that. Ill have to read over the documentation later and see if I can disable that check.
Could also just mean nothing tho.
Anyway, anybody know how I might be able to correct for this?
Injectors are new all around. Turning the car from off to run 5 times, then trying to start it with the gas held down results in no ignition so I shouldnt have a leaky injector AND the computer is obviously TRYING to add more fuel for whatever reason.
