F14CRAZY
To the flo...
- October 31, 2002
- Dimondale, Michigan
- '92 GT, '93 Limited
Howdy. My dad's work vehicle is a '98 Ford 3/4 ton Econoline 250. 4.6L. Around 225k miles with no real engine repairs. He did have the transmission rebuilt at 165k, but otherwise has been a good drivetrain. I think it's the 4R70W.
He's been one of those that kinda ignores CEL/SES lights, until it started running abnormally recently. It shakes/vibrates/shudders like when the torque converter is locked. When unlocked it runs close to normal but with some power loss.
I went ahead and bought our own code scanner. We needed one anyway with all of the vehicles we have and our DIY tendencies. I pulled the codes...
153: oxygen sensor before cat on bank 2 slow to respond. I picked up a new Bosch sensor and replaced it, so this code is no longer present. Yes, I know they all should be replaced...but anyway, after this I reset the codes. It still ran the same, and the CEL came back the next day
The codes below are currently present still:
301: cylinder 1 misfire. I installed new plugs about 10k miles ago. I wasn't sure which cylinder was 1 so I pulled the front plugs of both the driver and passenger sides and found them to still have a good gap and look normal (my dad agreed that they looked fine). I'm assuming that cylinder 1 is one of the front cylinders and not the rear . I searched the board for this code and it didn't find any posts that said what to do next if the plug's fine.
401: insufficient exhaust recirculation flow. I searched for this, and is most likely from a bad DPFE/EGR pressure sensor. If not that, then clean the EGR valve. Would this keep the engine from running bad? I'll fix it but want to go after 301 because I think that's most likely the cause of our shuddering.
What do you guys suggest? Bad coil or injector or something? Thank you.
