98-5.slow
- August 24, 2016
- Nj
- 98 explorer 5.0
so my truck has a cyl 6 miss code and a bank2 lean code. I've replaced entire ignition system plugs wires coils. Replaced injector did a compression test all within 2 points of each other so has good compression. Hooked a good ford scanner to truck and injectors are working fine. Could there be a bad sensor somewhere causing this. Also new maf sensor.
