jacques38
- September 5, 2014
- 1998 ford explorer xlt
1998 Ford Explorer XLT 4.0L.
So this issue has a little back story that may be relevant. At one point the AC was working great, ice cold air all the time, then one day it started blowing hot air. I switched the modes around and got hot air on every switch setting except for MAX AC. Running the AC on the MAX AC setting worked for a couple of months and then it quit working one day. Now every setting blows hot air and on top of that with EVERYTHING turned OFF heat is still seeping through the vents.
Now for the good part. Today I took apart the glovebox and removed the blend door actuator. It is functional when i turn the temperature knob. So that isn't the problem. Where should I look now?
