astig2
- August 21, 2009
- 1998 Ford Explorer EB
Having a problem with the brake lights on my Explorer. I have no regular brake lights when the pedal is pressed, but the third brake light (LED) works fine. The weird part is that even when the brake pedal is not pressed the third brake light continually flashes at a very high rate, almost like a strobe. As a sided note I also noticed that the door locks stopped auto locking when you put the vehicle in gear at about, or the exact same time the brake light problem started.
