bfsjr
- October 17, 2004
- midlothian, virginia
- 1993 explorer xlt
I have a 98 Explorer XLT which I've replaced the upper and lower ball joints, tie rod ends, hub/bearings, both cv axle shafts and I continue to have a whine at about 30 mph that is coming from the front. I noticed that the ATF has leaked out of the front differential on the passenger's side and also around the differential cover plate. I think the fluid drained out of the front differential some time ago. I believe the front differential bearings are worn and causing the whining. Does anyone know of any good pics on this forum showing how to take out the front differential and replace the differential bearings. Any help would be greatly appreciated.
BFS
BFS
