98 explorer4.0 sohc | Ford Explorer Forums - Serious Explorations
98 explorer4.0 sohc
Travis801
Ogde utah
98 Ford explorer 4.0 v6
can a p0133 code cause a p0174 code
at first it was a p0133 code witch is the bank one sensor one witch i need tochange out this weekendand today a p0174 code popped up
i have a 98 ford explorer eddie bauer with the4.0 sohc v.6
@Travis801
Not likely in my opinion. Replacing the right bank (bank 1) front O2 sensor might not get rid of the code(s) either. I would check fuel pressure first. If it is on the low side, replace fuel filter, if that has not been done for a long while. Still low, suspect fuel pressure regulator, then possibly pump. imp
change the sensor so far no codes
