98 mounty
- April 15, 2004
- Minnesota
- 97 Mountaineer
My rear brakes needed work, the rear rotors were shot. And they had quite a bit of rust on them. So I picked up new pads and rotors. After pulling the calipers I tried to pull the rotor, it wouldn't budge.
We first tried hitting it with a hammer, no luck. We then soaked it in penetrating oil, and hit it again, and again, and again... The we heated it up with the propane torch, all of these steps were repeated many times. About 2 hours later we got it loose. And some where in between all of that, we got the other side off with alot less effort.
Now, the problem. The rotor is hung up on the parking brake pads. We spent a good 2 hours trying to get it past the pads with no luck. And this is where we are stuck. It is currently on jack stands, and I am going to try again first thing in the morning.
Any ideas on how I can try to get it off?
