crimsonwhite33
- December 5, 2008
- georgia
- 98 ranger 4x4 xlt
I have a 98 ranger 4x4 that would'nt go into 4wd, the light on the dash would come on and the motor on the transfer case was working properly but the hubs wont engage. Iknow that they are operated using a vacuum so i checked for leaks in hoses and checked to see if i was getting vacuum from the vacuum solenoid. No leaks on hoses and i had vacuum but wasnt sure if it was getting enough to engage the hubs, so i tried putting vacuum directly to the hub and they engaged. Problem is that now they wont disengage even though i take the vacuum off, so now my hubs are locked and the axels and driveshaft turn all the time even though im in 2wd. im afraid that one might disengage while driving and cause damage. What would cause the hubs to stay locked? And where should i start to get this vacuum operated system to work properly? faulty vacuum solenoid? vacuum leak in hub? Any suggestions would be greatly appreciated! Thanks in advance!
