buckz6319
- December 6, 2012
- Ga
- 2013 Ford Edge
HI
I was replacing the L side lower ball joint, upper control arm with ball joint, and sway bar link
The lower ball joint was fairly easy to remove, but getting the new ball joint joint in , was a PITA..the press I got didn't do the job, felt like I was going to break the screw, at any moment, so I went back to what I know a BFH, and huge socket, ect. It took me hours to get it seated so I could put the snap ring on it.
I new ball joint had splines, but I didn't see any on the old ball joints. I am guessing it was still a factory joint
The new upper control arm with ball joint, installation was easy, but I think the diameter of the ball joint shaft is wee bit larger than the one I removed, maybe the old one was rusted so bad that it looked smaller? or did I get the wrong control arm?
I think I can spread the spindle some to get the shaft to drop in..
I would appreciate any suggestions on resolving my issue, thanks!
here is a pic of the upper control arm/ball joint
