98 Ranger unusual clutch problem please help!!
EvilTheCat
Lincoln NE
'97 Explorer
Are you doing the repair yourself?
I'm going to try.
Anything I need to worry about before tearing into this?
From what I've read on this forum it's not an easy job.
I'll start stretching tonight for the contortions I'll be doing tomorrow working under that dash.
EvilTheCat
Lincoln NE
'97 Explorer
Well I did it and a write with lots of pictures here. It was a lot easier than I originally thought it would be.
Jason Stockman
AZ
98 Ford ranger
Hopefully this will be read by someone who has experienced something similar or has enough insight to offer some assistance. I'll put the sequence of events in point form for easy reference:
1. I bought this truck (98 Mazda B3000/Ranger 3.0L 4WD 5Spd) 2 years ago
2. This truck had just received a new clutch from Autozone
3. For two years, the clutch seemed unusually stiff, but I chalked it up to being a truck....my left leg is twice as stiff as the right now...LOL
4. Earlier this year, I started having a hard time engaging low gears and it would often grind
5. Things got horrible worse and last weekend, I would have to shut the engine down to be able to shift the truck in 1st and take off, beyond that I would shift without the clutch
6. I took it in for a clutch master replacement, thinking that if my slave had gone bad, it would have leaked
7. The mechanic replaced the clutch master and called me to tell me that the new master had blown the slave because it was weak
8. Not wanting to pay them to pull the tranny, I did it at a friend's shop
9. At that time, I noticed that the release bearing was shot as well
10. I bought an aftermarket slave, which didn't have a release bearing, but it had a plastic spacer with bellows over the return spring. The whole setup was very unusual, so I only used the slave cylinder portion and the old return spring with the new release bearing
11. After hours of bleeding, there was no clutch actuation to speak of and the pedal continues to be soft.
12. Not knowing what to do, we decided to put yet another new clutch master in
13. The new clutch master still did nothing and hours of different bleeding techniques, starting with gravity bleeding and finishing with conventional slow or fast pumping until the fluid coming out was beyond perfect
14. At this point, the theory is that the pressure plate took a set and the slave is at its end of the stroke. This is where we're stumped. What the heck is going on? The pressure plate fingers stick out significantly and everything appears normal. If you wedge a screwdriver between the release bearing and the pressure plate, the clutch pedal seems to get some pressure.
Has anyone encountered a situation where the slave appears to be at the end of its stroke? What the heck was up with that slave that I got from the parts place which appeared to have a plastic spacer in place of the release bearing? The auto parts supplier up here in Canada is quite reputable and the product appeared identical to what came off the truck, except for the plastic spacer. The part number and other numbers on it matched the old one to a tee. I really need help on this one, as I'm at wit's end. I have sunk so much money into this problem and I'm having a hard time understanding why this is such an issue. I've done countless clutches, including all kinds of hydraulic clutch system service and have never encountered this....any thoughts?
Was the clutch itself installed backwards if memory serves me correctly when I replaced my clutch I could see that if it was installed backwards I had thought would be the problem with you not being the one that installed it I the first place & sounds like you have done everything else. maybe can't hurt to check
G 1997 Ford Ranger Super Cab seat replacement? Ford Ranger - Mazda B-Series Forum 0
C 2003 ford ranger Ford Ranger - Mazda B-Series Forum 0
E Free Ranger fenders 2001 So California Ford Ranger - Mazda B-Series Forum 0
A Ford Ranger Ford Ranger - Mazda B-Series Forum 4
allmyEXes 1999 Ranger-Towing a 3.0 with automatic transmission Ford Ranger - Mazda B-Series Forum 4
Paul Paul's 2011 Ranger FX4 Ford Ranger - Mazda B-Series Forum 37
B Looking at buying 01 Ranger. Advice? Ford Ranger - Mazda B-Series Forum 4
D Relacing 3.0 in ranger w/manual trans Ford Ranger - Mazda B-Series Forum 3
E 2002 Ranger 4WD Light Stays On Ford Ranger - Mazda B-Series Forum 2
M 1994 4.0L Ranger. No start condition. The computer isn't powering up. Ford Ranger - Mazda B-Series Forum 3
C 1985 Ranger rear axle ? Ford Ranger - Mazda B-Series Forum 10
410Fortune 410Custom's builds a 2007 Ranger V8 - custom truck build - Project "Ranger Premier" Ford Ranger - Mazda B-Series Forum 187
H 5.0 4x4 Ranger. Ford Ranger - Mazda B-Series Forum 6
D Intermittent Starting - 2003 Ford Ranger XLT Fx4 4.0 Ford Ranger - Mazda B-Series Forum 0
B 1988 ranger 5 speed. turn key and nothing. Ford Ranger - Mazda B-Series Forum 4
E Land Rover LR3 4.0L V6 Replace with 2008 Ranger VIN E Ford Ranger - Mazda B-Series Forum 73
M 2003 Ranger 3.0 - Idle drops to 300rpm when AC is on Ford Ranger - Mazda B-Series Forum 2
F 2011 Ford Ranger Air Conditioning Ford Ranger - Mazda B-Series Forum 2
C 98 ford ranger 4.0l few codes Ford Ranger - Mazda B-Series Forum 0
R 2000 Ranger Overdrive issues Ford Ranger - Mazda B-Series Forum 9
D locate oil lite sensor 2000 ford ranger 4whd short box sohc v6 Ford Ranger - Mazda B-Series Forum 2
T Ranger 3.0 Tricky Misfires Ford Ranger - Mazda B-Series Forum 1
M 1997 Ranger clutch disengagement problems Ford Ranger - Mazda B-Series Forum 4
T 1990 Ranger 2.9L 5spd manual? Ford Ranger - Mazda B-Series Forum 28
S 1993 Ford ranger M5R1 3.0 L manual 5spd transmission installation issue Ford Ranger - Mazda B-Series Forum 10
R 2002 ranger gets 21 starts. Ford Ranger - Mazda B-Series Forum 0
S my first ranger 97 was a gift? Ford Ranger - Mazda B-Series Forum 0
R suggestions on converting a 94 Ranger to 2000 explorer engine and tranny Ford Ranger - Mazda B-Series Forum 2
S 2003 Ranger XLT 4.0L PCM pinout Ford Ranger - Mazda B-Series Forum 4
J 1994 ranger automatic Hubs Ford Ranger - Mazda B-Series Forum 1
M fueling 1992 ranger two wheel drive Ford Ranger - Mazda B-Series Forum 4
R 2002 Ranger Door Not Closing Properly Ford Ranger - Mazda B-Series Forum 1
P '02 Ranger 3.0l Fine Wire Spark Plugs Burnt off Ford Ranger - Mazda B-Series Forum 0
C 1992 ford ranger 3.0 no power to fuel pump and like radio Ford Ranger - Mazda B-Series Forum 2
P 96 Mazda B2300/Ford Ranger starts but shuts off Ford Ranger - Mazda B-Series Forum 3
S 88 Ranger 2.9L oil light flickers at low RPM Ford Ranger - Mazda B-Series Forum 1
T 1997 Ford Ranger 4.0 Evaporative Emissions System Line Ford Ranger - Mazda B-Series Forum 4
M 2000 Ranger Very Rough Idle Ford Ranger - Mazda B-Series Forum 0
S 01 ranger supercab Ford Ranger - Mazda B-Series Forum 2
A Ranger won't go. Ford Ranger - Mazda B-Series Forum 1
J 1994 Ranger Multifunction switch diagram or help Ford Ranger - Mazda B-Series Forum 1
J 2000 ford ranger 2.5 Ford Ranger - Mazda B-Series Forum 1
4pointslow My 2001 Ranger Edge 4x4 Supercab Ford Ranger - Mazda B-Series Forum 129
J 1994 Ranger 3liter chronic ICM failures Ford Ranger - Mazda B-Series Forum 4
8 Ranger wont go into drive Ford Ranger - Mazda B-Series Forum 1
J 99 FORD RANGER 4X4 DRIVE ISSUE Ford Ranger - Mazda B-Series Forum 1
J Modified Ranger, help with 5.0 Ford Ranger - Mazda B-Series Forum 6
L 1996 Ranger Ford Ranger - Mazda B-Series Forum 1
D Hello have a 94 Ranger giving me fits Ford Ranger - Mazda B-Series Forum 14
R 3 Relays I do not know what they are - 2001 Ranger Ford Ranger - Mazda B-Series Forum 0
Similar threads
