chefduane
Texas Elite Explorer
- January 22, 2013
- Location
- TEXAS!
- Plano, TX.
- None: SOLD 9/16
98 4.0L SOHC XLT 4x4 181k miles
I am trying to run down a hard starting problem on the above vehicle. I have previously had the upper & lower manifold gaskets done some time ago. I have also done a MAF and IAC cleaning and changed the Cam Position Sensor myself. Wires/Plugs were also done a few years ago. When she runs, she runs great. No hesitations, acceleration from a stop is fine and acceleration from 60-80 is fine. Seafoamed her a few months ago and all went well. And no timing change issues so far (knock on wood). Regular maintenance at recommended intervals. But she starts hard.
There is no "pump prime sound" at all when I switch the ignition to on. I have also completed the "whack it with a mallet" test procedure (!) to no avail.
Here is where I am today:
1. Checked voltages to the Inertia Switch. FPR & PCM relays are fine and all fuses are ok. I get a +12v (+/- .5v) spike at the Inertia Switch when ignition is switched to on. I HAVE NOT checked voltages at the Fuel Pump.
2. Using 2000StreetRod's Fuel Pressure Test Procedure (tnx 2kSR) I have zero (0) pressure at complete rest. No pressure to relieve when beginning the procedure.
3. When the ignition is turned to the ON position the pressure slowly comes up to barely 30psi but never above. Tested that a few times. No changes.
4. Pressure at idle is also 30psi, no changes. Again, tested a few times.
5. When slow revving to 3000RPM the pressure also NEVER moves from 30psi.
6. When fast revving to 3000RPM the pressure goes from 30psi to about 36psi but never gets to 40psi. When idling back down, the pressure settles back to 30psi. Again, retested a few times, no changes.
7. When the engine is turned off, the pressure quickly dissipates to zero within 30 seconds. There is no residual pressure that remains after 30 seconds or so.
This is where I hit a snag. Where the heck is the vacuum line at the rear of the intake? I know it is probably obvious, but not to me. Is it the vacuum line that comes off the brake booster? I can't really make it out in the pic in the test procedure. I know I need to test the pressure with the vacuum line disconnected and plugged.
That's where I am so far. Any input would be appreciated. I am thinking it is a fuel pump problem but am not sure. Since I am getting some pressure build when the ignition switch is in the ON position I assume that I am getting voltage to the fuel pump and the pump is putting out SOME pressure. Is that a correct or erroneous assumption?
Also, If I do need the check the voltages at the pump, I am considering doing the "floor pan fuel pump door access mod" and NOT dropping the tank. That way I can check the voltages and swap the pump if need be. (Besides, my wife wants me re-do the shower stall and I'll CERTAINLY need me a Harbor Freight Air Chisel remove the tile!!!)
Any thoughts or input would be appreciated!!
Thanks.
Chef Duane
Plano, TX.
Thanks.
Chef Duane
Plano, TX.
